C# BackgroundWorker AxCWGraph 7.1
Measurement Studio 7.1 - C# .Net 2.0 application.
When trying to create an instance of AxCWGraph in a BackgroundWorker the following error appear:
"ActiveX control 'b68dbfab-16a0-11ce-80bf-0020af31cef9' cannot be instantiated because the current thread is no a single-threaded apartment".
I would like to take snapshots of  runtime generated graphs that contain a lot of data. this takes a lot of time and stuck the application. I would like that the main application will continue running normally and  the graph snapshots/images will be done in the background.
I would appreciate your help
Thanks in advance'
oren
(3,883 Views)
Hi Oren,
The following KnowledgeBase article was written for TestStand however I think the same logic applies:
Why am I Seeing Single-Threaded Apartment Errors When Launching a Module Containing ActiveX Controls in TestStand?
http://digital.ni.com/public.nsf/allkb/3F46208C73E6C92186256E9900758D6A?OpenDocument
The key line may be "because ActiveX does not support multithreading". Unfortunately this means you wont be able to implement the solution with a BackgroundWoker, you may have to look into ways of reducing the amount of data in your graph, so you can get both operations working in the same thread.
Scott M.
(3,860 Views)
