C# DAQmx Switch Warnings
I have recently upgraded (?) to VS2013 and Measurement Studio 2013.
I am now receiving 'Warnings' that  "NationalInstruments.DAQmx.Device.Switch' is obsolete" - as are all methods concerned with said switches.
This IS a problem - we operate a 'Treat all warnings as errors' policy 😞
So...
From reading the documentation...
It would appear that Switch control has been removed from DAQmx - and is now located in NI-Switch.
No problem then - I will just have to install NI-Switch 🙂
But...
Ni-Switch supports the following...
Application Development Environments (ADEs)
Note:  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI or Microsoft Visual Studio®, before installing NI-SWITCH. To add support for ADEs installed after installing NI-SWITCH, modify your NI-SWITCH installation or launch the NI-SWITCH installer again.
  • LabVIEW 2012 SP1 (32-bit), 2012 SP1 (64-bit), 2013 SP1 (32-bit), 2013 SP1 (64-bit), 2014 SP1 (32-bit), 2014 SP1 (64-bit), 2015 (32-bit), or 2015 (64-bit)
  • LabVIEW Real-Time Module 2012 SP1, 2013 SP1, 2014 SP1, or 2015
  • LabWindows/CVI 2012 or later
  • LabWindows/CVI Real-Time Module 2012 or later
  • Microsoft Visual C++ (MSVC) 6.0 or later
  • If you are running your application on an RT target, 128 MB of memory or more is required.
So - NO Measurement Studio support. 😞
And this appears to be the case - I can find no way to actually 'Reference' the NI-Switch Assembly.
(Yes - I can 'Reference' the NI-Switch COM Library - but this points to the 64bit version (4.8.0f.) which cant be loaded into my 32-bit Application)
Am I just being stupid - or is there a way to do this that I am missing?
Surely NI would not depreciate one library without replacing it with the alternative 😞
Thanks for your help.
(5,402 Views)
Did you see http://www.ni.com/example/26648/en/
(5,391 Views)
Hiya nyc,
Thanks for the reply.
I had seen that - thanks.
And, indeed, I have used it as a base for my own class.
But...
It really is such a backward step Smiley Sad
Control of switches used to be possible in native C# code in DaqMX - which was good.
Now it has to be done using un-managed external code - which is bad.
I can see no way in which this can be classed as an improvement.
I am assuming (I know - I know) that NI are working on a native C# class for NI-switch Smiley Happy
Which means more changes to the code - and subsequent regression testing.
But, surely, this should have been in place before switch control was removed from DaqMX.
Unfortunately, from the lack of responses, it looks like I am possibly the only person suffering this problem.
I am aware that Measurement Studio is not NI's #1 priority - but some acknowledgement would be nice.
Bryan.
(5,253 Views)
Take a look here:
https://www.ni.com/en/support/documentation/supplemental/15/ni-switch--net-resources.html
Is that not what you're looking for?
(5,231 Views)
Hi Evancox10,
That is EXACTLY what I was looking for Smiley Happy Smiley Happy
Thank you - and much Kudos for finding it Smiley Happy
Don't know why I never looked in Product Documentation for it Smiley Surprised
Bryan
(5,225 Views)
@BryanUK wrote:
Hi Evancox10,
Bryan
I thought your intention was NOT have to switch to NI-Switch?
(5,215 Views)
