[C#] Getting the maximum number of physical channels of a device
Hello all,
Is there a way to get the maximum number of physical channels (analog in/out, digital in/out) of a connected device?
I have a couple of USB DAQs, one has 4 differential Analog Outputs, the other has 40 differential analog outputs.  I want the ability to make some decisions based on their analog output counts.  Is there a property somewhere in the measurement studio C# library I can use?
Joe
(2,869 Views)
Hi Joe,
I've attached an example program below that uses Microsoft Visual C# to Find all VISA resources available to perform communication. It would be a great place to start looking or even use in your application.
Using Microsoft Visual C# to Find all VISA Resources and Perform Communication
ShaneK
Applications Engineering
(2,839 Views)
@2Shanez wrote:
Hi Joe,
ShaneK
Hi Shane,
Thanks for an answer.  I looked up the program you posted about (Using Microsoft Visual C# to Find all VISA Resources and Perform Communication), and it's very old.  It was developed using VS2002 and I can't find the references it's using.
Thanks for the heads up, but this problem is still open.
Joe
(2,829 Views)
Hi Joe,
Do you have NI-VISA installed for .NET? I did a little digging and found that the NI-VISA .NET Class Library lists a Find method that we could use similar to that example. I have included the download link to the latest NI VISA Driver Download as well as the help page for the FindResources Method Below.
NI-VISA 17.0: https://www.ni.com/en/support/downloads/drivers/download.ni-visa.html#306036
FindResources Method: http://zone.ni.com/reference/en-XX/help/370627F-01/mstudiowebhelp/html/3cb332e6/
ShaneK
(2,818 Views)
