C#.Net Listen Only and ReadByteArray
I have a NI GPIB-USB-HS adapter running the 488.2 3.1.2 drivers.
It runs a C app in listen-only mode and captures bus data strings well.
I'm trying to get the same functionality using C#.Net.
So far I have tried the following code snippet in VS2010 (.Net 4.0)
with the corresponding NI 488.2 and Common assemblies referenced by the project.
Here is a snippet...
Form...
  private Board board = null;
Form_Load...
  try {
    board = new Board(0);                  // ibfind(GPIB0);
    board.Reset();                         // ibonl();
    board.ListenOnlyMode = true;           // ibconfig(GPIB0, IbcLON, 1)
    board.IOTimeout = Timeoutvalue.t300ms; // ibconfig(GPIB0, IbcTMO, T300ms)
  catch {
Form_Shown...
  while(running)
    Application.DoEvents();
    try {
      data = board.ReadByteArray(256); // ibrd
      length = board.LastCount;        // Ibcnt
    catch {
With the NI GPIB-USB-HS adapter disconnected from any GPIB host or devices,
the ReadByteArray lands in the catch every 300ms per the timeout value as expected.
With the NI GPIB-USB-HS adapter connected to a GPIB host and devices with data flowing,
the ReadByteArray method ends up in the catch everytime still and the length is always 0.
Polling in C (ibrd/Ibcnt) is the only way I have been able to get Listen-Only to work.
What needs to be done in .Net to make Listen-Only work?
Here is a list of the calls in C that I use for Listen-Only to work...
Setup...
  Bd = ibfindA("GPIB0");
  ibonl(Bd, 0); // Take board offline - loses handle
  ibconfig(Bd, IbcSAD, 0x00);
  ibconfig(Bd, IbcLON, 1);
  ibconfig(Bd, IbcTMO, T300ms);
Poll...
  ibrd(Bd, ReadBuffer, 256);
  length = Ibcnt();
Steve
(7,751 Views)
I dont have direct answer for you but i think this article might help you in writting your code in C# .NET
http://zone.ni.com/reference/en-XX/help/370628F-01/mstudiowebhelp/html/gpibapimapping/
(7,729 Views)
I use that table all the time...
Steve
(7,727 Views)
(7,688 Views)
Yes, I started with those examples a while back. If I recall correctly, they used the device class. I've gone the route of the board class. None of the .Net examples covered Listen-Only.
(7,685 Views)
What happens when you try to read only single byte?
Do you know which expections are thrown?
(7,661 Views)
