Callbacks and number of acquired samples
Hi all,
in my application i need to acquire data through a pcie 6323 with C# .Net.
For my purpose when i start the software the NI card is configured to acquire data in continuoussample mode.
After user acts on main form and press start button, i call again
analogInputTask.Timing.ConfigureSampleClock(
ClockSource
, SampleRate
, ActiveEdge
, SampleMode  // starts in continuous  samples to switch to finite samples when acting on main form
, samplesPerChannel);
with samplemode = finitesamples
The callback i use to call through  following lines of code:
 this.analogInputAsyncResult =
this.analogReader.BeginReadWaveform(
SamplesPerChannel
, analogInputReaderCallback
, analogInputTask
 is this:
private void AnalogInCallback(IAsyncResult ar)
            try
                if (runningAnalogInputTask != null && runningAnalogInputTask == ar.AsyncState)
                    /// Handles the end of an asynchronous read initiated with
                    /// BeginReadWaveform and retrieves the read samples.
                    /// REMARKS
                    /// If you call EndReadWaveform before the asynchronous read
                    /// represented by the provided IAsyncResult is complete,
                    /// EndReadWaveform waits for the read to complete before returning.
                    analogInputReaderData = analogReader.EndReadWaveform(ar);
                    try
                        double[] buffer = new double[SamplesPerChannel];
                        DateTime[] dtBuffer = new DateTime[SamplesPerChannel];
                        using (TimedLock.Lock(AnalogInputs))
                            if (analogInputReaderData != null && analogInputReaderData.Length > 0)
                                try
                                    foreach (SampleBuffer<double> input in AnalogInputs)
                                        var inputData =
                                            .Where<AnalogWaveform<double>>(r => r.ChannelName.Equals(input.Name))
                                            .Single();
                                        /// Read samples
                                        inputData.GetBuffer(true).CopyTo(buffer, 0);
                                        input.AddSamples(buffer);
                                        /// Read timestamps
                                        inputData.GetTimeStampBuffer().CopyTo(dtBuffer, 0);
                                        input.AddTimeStamps(dtBuffer.Select(dt => dt.Ticks));
                                    OnSampleBufferChanged(new SampleBufferChangedEventArgs(AnalogInputs));
                                catch (Exception ex)
                                    Debug.WriteLine(ex.Message);
                    catch (LockTimeoutException) { }
                    /// Restart reading
                    analogReader.BeginMemoryOptimizedReadWaveform(
                          SamplesPerChannel
                        , analogInputTask
                        , analogInputReaderData
            catch (DaqException ex)
#if DEBUG
#endif
                runningAnalogInputTask = null;
                analogInputTask.Dispose();
i'd like to ask you if with the check i do with
is correct to see if there is incoming acquired samples. What i mean is that when i switch to finitesamples the callback is the same so before the trigger starts i want to not perform any processing on the acquired data premise that there is a way to check that buffer is empty 'cause the trigger is not yet started.
Thanks in advance
(5,214 Views)
Consider looking at the C# examples that should have been installed during your installation of NI-DAQmx.
(5,186 Views)
Sure, but it would be better if some NI expert share with me some link with deep explanation of this.
Also when i've tried to modify the code to understand it better i've noticed that callback is called also when board is in finite sample mode and trigger is not yet detected.
Now instead the callback in the same situation is called only if trigger is detected
(5,132 Views)
