Can someone verify this 1AI/2DI Program??
Hello Pavan,
I looked at the AI code you had posted previously and it looks like you are reading in the signal at 10MHz and then generating at 4MHz.  If this is the case, you should see a decrease of the generated frequency because you are acquiring 2.5 times as many samples per second as you are generating.  Double check your code and make sure that you really are both acquiring and generating at the same rate.  If you are you should be generating the signal at the same frequency.
Micaela N
Message 11 of 11
(1,018 Views)
