04-02-2015 12:46 PM
I have a weird situation...
I programmatically add plots to my ni :Graph (C#)
ChartCollection<double, double> chartCollection = new ChartCollection<double, double>();
Plot plot = new Plot(label);
plot.Renderer = new LinePlotRenderer() { Stroke = brush, StrokeThickness = 0.5 };
graph.Data.Add(chartCollection);
graph.Plots.Add(plot);
chartCollection.Append(Initializer.DictionaryOfAllPossibleFrequencySteps[frequencyStep].frequencyVal, realVal);
Everything works nicely except when I try to zoom using GraphInteractionPalette, the very LAST added plot stays static while everything else is zooming.
For some reason if I add a "dummy" plot (with no data) when I'm done adding real plots, everything zooms fine... including the last plot. It's almost like the last plot is not being "released" or something. Am I missing some call?
Thank you.
Solved! Go to Solution.
04-02-2015 05:02 PM
Based on your example code, I was able to reproduce the issue and have created a task to fix this for the next release of Measurement Studio.
As a workaround, adding the plot to the graph before the data is added seems to avoid the problem:
08-11-2015
01:20 PM
- last edited on
11-20-2024
08:22 AM
by
Content Cleaner
Just wanted to let you know this issue (#476665) was fixed in the Measurement Studio 2015 release.
08-11-2015 01:24 PM
Yes, thank you... I tried it right away when got 2015 and confirmed it but forgot to mention here.
Also, offtopic.... GraphInteractionPalette doesn't delay WPF wondow loading anymore. I know there was a thread about it but not originated by me,
Thanks!
