Cannot find custom tool MxbCodeGenerator after VS2005->2008 conversion
I am limping along in C# and recently converted a VS2005 C# project with Measurement Studio 2009 to VS2008 using the VS conversion wizard.  Since then the VS2008 project has been building and running great, until today when I tried modify my VisaTask1.mxb assistant.  When I did that, I got a warning on the build saying:
"Cannot find custom tool 'NationalInstruments.MeasurementStudio.Tools.DotNET.MxbCodeGenerator' on this system."
I am pretty sure that the MxbCodeGenerator must be on the system somewhere.  In my project I have working references to NI.Common, NI.UI, NI.UI.WindowsForms, and NI.VisaNS .  Does anyone know how I can locate this MxbCodeGenerator tool again?  Without it my automatically generated VisaTask1.cs code cannot update.
Penny
(4,024 Views)
Hello Penny,
Thanks for posting. When you look at the properties of your component (VisaTask1.mxb), the "Custom Tool" property should refer to "NationalInstruments.MeasurementStudio.Tools.DotNET.MxbCodeGenerator.2008".
If the "Custom Tool" property is empty or wrong (i.e. just says "NationalInstruments.MeasurementStudio.Tools.DotNET.MxbCodeGenerator"), add the .2008 to the end.
Another troubleshooting step might include adding a new component and observing what the exact property contents are. You can then set these for the old component you are trying to convert. I have seen some cases where you had to fill in the Custom Tool property of the .mxb file by hand to get it to generate code.
Mallori
Mallori M
Sr Group Manager, Education Services
ni.com/training
(4,000 Views)
Accepted by topic author Penny
Mallori,
It worked!  Thanks so much.  I just added the ".2008" as you suggested and now my VisaTask1.cs is updating again.
These discussion boards are just the greatest thing since sliced bread.  Smiley Very Happy
-Penny
(3,990 Views)
Glad to hear it worked 🙂 Good luck!
Mallori
Mallori M
ni.com/training
(3,983 Views)
