Cannot locate all output parameters required from DAQmx task read values using measurement studio.
We were using Traditional DAQ earlier with Borland C++.
We were using NIDSA_read_measurement (dsa_session, ipchannel, 0,measurement_length, 2, 0, 1,0, &x0, &dx, measurement); to calculate frequency and magnitude as shown
below:
objCurrentMagnitude = x0 + i * dx;objCurrentFrequency = measurement[i] * 1000 ;
 We are planning to use DAQmx with NI card 4461.
We will make use of measurement studio to define drivers etc. We read continous data from card.
Then we define a   DaqTask1Component in our C# code and read data on its DataReady event.
AnalogWaveform<double>[] contains the data read from the cards and i can fetch value from
 void objDaqTask_DataReady(object sender, DaqTask1ComponentDataReadyEventArgs e)
  for(int i=0;i<e.GetData()[0].Samples.Count;i++)
  double val = e.GetData()[0].Samples[i].Value;
        //Frequency - How to calculate. In traditional C++ it was objCurrentMagnitude = x0 + i * dx;
      //Magnitude - How to calculate. In traditional C++ it was objCurrentFrequency = measurement[i] * 1000 ;
How can i calculate the magnitude and frequency in DAQmx as i was doing with Traditional DAQ?
Do i need three parameters i.e. x0,dx,measurement here?If yes, where can i found the three parameters to calculate the freq and magnitude?
Nirdesh
Message Edited by Nirdesh on 05-05-2009 02:30 AM
(4,087 Views)
Duplicate
Simran K
(3,979 Views)
replied in the duplicate post...
.......^___________________^
....../ '---_BOT ____________ ]
...../_==O;;;;;;;;_______.:/
.....),---.(_(____)/.....
...//____//......
..//____//......
.//____//......
(3,916 Views)
