Cant use the board.findlisteners function due to CIC problem
I'm writing a vb.net program controlling a Keithly SMU via a NI gpib-usb-hs card.
One of the first steps is to locate available instruments.
I  have tried using the following code:
Imports NationalInstruments
Public Class cKeithley
    Public Function AvailableInstruments() As List(Of Integer)
        Dim availInstr As New List(Of Integer)
        Dim gpib As New NationalInstruments.NI4882.Board(1)
        Dim adrLst As NationalInstruments.NI4882.AddressCollection = gpib.FindListeners
        For Each adr As NationalInstruments.NI4882.Address In adrLst
            availInstr.Add(adr.PrimaryAddress)
        Return availInstr
    End Function
End Class
Several problems arise:
1. I have to specify address 1 in the constructor call to the board otherwise I get an out of range exception ("
Dim
gpib AsNew NationalInstruments.NI4882.Board(1)")
and more importantly
2. In the code above the FindListeners call gives a CIC exception.
Why isn't the gpib board CIC?. No other cards are plugged into the computer.
/mijq
(3,798 Views)
    Private gpib As NI4882.Board
    Private mDevice As NI4882.Device
        If CheckForBoards() Then
            Dim adrLst As NI4882.AddressCollection = gpib.FindListeners
            For Each adr As NI4882.Address In adrLst
        End If
        Return availInstr
    End Function
    Private Function CheckForBoards() As Boolean
        Dim availBoards As New List(Of Integer)
        For i As Integer = 0 To 5
            Try
                gpib = New NI4882.Board(i)
                availBoards.Add(i)
            Catch ex As Exception
            End Try
        If availBoards.Count = 0 Then
            MessageBox.Show("No GPIB card")
            Return False
        ElseIf availBoards.Count = 1 Then
            gpib.PrimaryAddress = availBoards(0)
            mDevice = New NI4882.Device(gpib.PrimaryAddress, 1)
            Return True
        ElseIf availBoards.Count > 1 Then
            MessageBox.Show("More than one GPIB card!")
            Return False
        End If
    End Function
End Class
OK, found a sort of solution myself (se code)
/mijq
(3,797 Views)
Hi mijq , can you give a link toward the source of this code snippet? I'm hoping that they have some more examples of using ni4882.dll in .NET
(3,692 Views)
