06-16-2011 06:41 AM
I'm writing a vb.net program controlling a Keithly SMU via a NI gpib-usb-hs card.
One of the first steps is to locate available instruments.
I have tried using the following code:
Imports NationalInstruments
Public Class cKeithley
Public Function AvailableInstruments() As List(Of Integer)
Dim availInstr As New List(Of Integer)
Dim gpib As New NationalInstruments.NI4882.Board(1)
Dim adrLst As NationalInstruments.NI4882.AddressCollection = gpib.FindListeners
For Each adr As NationalInstruments.NI4882.Address In adrLst
availInstr.Add(adr.PrimaryAddress)
Return availInstr
End Function
End Class
Several problems arise:
1. I have to specify address 1 in the constructor call to the board otherwise I get an out of range exception ("
Dim
gpib AsNew NationalInstruments.NI4882.Board(1)")
and more importantly
2. In the code above the FindListeners call gives a CIC exception.
Why isn't the gpib board CIC?. No other cards are plugged into the computer.
/mijq
06-16-2011 08:07 AM
Private gpib As NI4882.Board
Private mDevice As NI4882.Device
If CheckForBoards() Then
Dim adrLst As NI4882.AddressCollection = gpib.FindListeners
For Each adr As NI4882.Address In adrLst
End If
Return availInstr
End Function
Private Function CheckForBoards() As Boolean
Dim availBoards As New List(Of Integer)
For i As Integer = 0 To 5
Try
gpib = New NI4882.Board(i)
availBoards.Add(i)
Catch ex As Exception
End Try
If availBoards.Count = 0 Then
MessageBox.Show("No GPIB card")
Return False
ElseIf availBoards.Count = 1 Then
gpib.PrimaryAddress = availBoards(0)
mDevice = New NI4882.Device(gpib.PrimaryAddress, 1)
Return True
ElseIf availBoards.Count > 1 Then
MessageBox.Show("More than one GPIB card!")
Return False
End If
End Function
End Class
OK, found a sort of solution myself (se code)
/mijq
08-02-2012 03:27 PM
Hi mijq , can you give a link toward the source of this code snippet? I'm hoping that they have some more examples of using ni4882.dll in .NET
