Change Detection on single line don't work C#
I'm trying to developp an application to detect the change in a single line of my NI USB-6212.
My code is this:
// Create the task.
myTask = new Task();
// Create channel
string channelName = "Dev1/port0/line0";
myTask.DIChannels.CreateChannel(channelName, "", ChannelLineGrouping.OneChannelForEachLine);
// Configure digital change detection timing
myTask.Timing.ConfigureChangeDetection(channelName, channelName, SampleQuantityMode.ContinuousSamples, 1000);
myTask.SynchronizeCallbacks = true;
myTask.DigitalChangeDetection += MyTask_DigitalChangeDetection;
// Create the reader
myDigitalReader = new DigitalSingleChannelReader(myTask.Stream);
// Start the task
myTask.Start();
But when I run the code line:
I  have this exception:
Error=-200077
Message="Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property."
Property: NationalInstruments.DAQmx.Timing.SampleTimingType
Requested Value: NationalInstruments.DAQmx.SampleTimingType.ChangeDetection
Possible Values: NationalInstruments.DAQmx.SampleTimingType.OnDemand
Task Name: _unnamedTask<0>
Status Code: -200077
Does anyone have any idea what is the problem ?
Thank you in advance for your answers
(2,832 Views)
unfortunately this is an expected behavior.
The USB-6212 doesn't support the HW change detection feature.
What are you trying to do? Why HW change detection?
(2,785 Views)
Thank you for the reply..
I wanted to check some emergency sensors and report any anomalies if they change status without having to constantly check them through my software.
My solution will be my background task that will control the state of the lines every X time.
(2,783 Views)
