Changing X-Scale of ComplexWaveform plotted with WaveformGraph control (Plotting FFT Data)
Development Environment:
* Microsoft Visual Studio 2010 Pro
* C# Language
* National Instruments Measurement Studio 2012
Summary of Question:
* I'm plotting data from a Fast Fouirer Tranform (FFT)
* The scale on the X-Axis is currently the number of BINS in the FFT.
* I want the scale on the X-Axis to be the Frequency (which should be from 0 Hz to 1000 Hz)
More Thoughts on the Question:
* Lets say the number of data-samples I'm collecting is 4096 at a frequency of 2000 samples/second.
* This results in an FFT that has 2048 BINS and should represent frequencies from 0 to 1000 Hz.
* If I just plot the data as-is...I get an X-Axis from 0 to 2048.
* There is a scaling factor that I could multiply X by to get the proper X values. (I have that)
The problem is the X-Values for the plot are the ARRAY INDICES...and those obviously have to be whole numbers.
Code I'm Using...simplified with irrelevant thigns left out:
void PlotFFT(System.Numerics.Complex[] FFT_Result_Bins)
  // Create an object that describes the properties of how the plot should be created.
  ComplexDataPart complexDataPart = ComplexDataPart.Real;
  ComplexWaveformPlotOptions complexPlotOptions = new ComplexWaveformPlotOptions(
                ComplexWaveformPlotDisplayMode.Samples,
                ComplexWaveformPlotScaleMode.Scaled, complexDataPart);
  const int DataSamplingRate = 2000;
  const int DiscernableFrequency = DataSamplingRate / 2;
  int NumberOfBins = FFT_Result_Bins.Length;
  double HzPerBin = DiscernableFrequency / NumberOfBins;
 // Generate an array of doubles from the FFT_Result_Bins.
 var dataPoints = new ComplexDouble[NumberOfBins];
  for (int x = 0; x < NumberOfBins; x++)
      dataPoints[x].Real = FFT_Result_Bins[x].Real;
      dataPoints[x].Imaginary = FFT_Result_Bins[x].Imaginary;
  // Create a WaveForm data strcuture/object from the array of data (doubles).
  ComplexWaveform<ComplexDouble> waveform = ComplexWaveform<ComplexDouble>.FromArray1D(dataPoints);
  // Plot the graph using a separate thread.
  this.BeginInvoke(new MethodInvoker(delegate()
  {waveformGraphFreqDomain.PlotComplexWaveform<ComplexDouble>(waveform, complexPlotOptions);}));
Thanks for any help!
gw
(5,461 Views)
Hello Jabadoodle,
Thank you for the thorough post.
Setting up your graph, with ComplexWaveformPlotDisplayMode set for samples, and plotting a waveform with 2048 data points would work as you are seeing.
I haven't configured any complex data to test this with; however based on the PlotComplexWaveform help example, you should be able to set the DisplayMode to Time and then configure the X-Axis to not display the samples. This may be configurable to show what you want. Have you tried that? What have been the results?
ComplexWaveform<ComplexDouble> waveform;
ComplexWaveformPlotOptions options = new ComplexWaveformPlotOptions(ComplexWaveformPlotDisplayMode.Time,
        ComplexWaveformPlotScaleMode.Raw,
        ComplexDataPart.Real);
GetRandomComplexWaveformData(out waveform);
// Set the X-Axis to display time
wvfmGraph.XAxes[0].MajorDivisions.LabelFormat = timeFormatString;
// Set the Y-Axis to display samples
wvfmGraph.YAxes[0].MajorDivisions.LabelFormat = samplesFormatString;
if (wvfmGraph.Plots[0].Mode != WaveformPlotMode.PlotComplexWaveform)
    wvfmGraph.ClearData();
wvfmGraph.PlotComplexWaveform<ComplexDouble>(waveform, options);
Jacob R. | Applications Engineer | National Instruments
(5,445 Views)
Jacob, thanks for the suggestion.
I found I could get what I wanted by turning off the X-Axis Major & Minor division lines...then creating my own custom divisions on the X-Axis where I need them to be.
This is working for now, but I'll try DisplayMode as Time becuase I'm curious if that will do it and be simpler.
Thanks again!
(5,438 Views)
