Charting of multiple plots in the same ni graph
I want to chart multiple plots in the same ni graph, by using the WPF version of Measurement Studion 2013 (VS2012).
Your wpf charting example is modified with a declaration of two plots in the graph instead of one - see the enclosed project: MainWindow xaml file.
My problem is that I'am only able to update one of the plot in the GenerateData timer callback function.
I have tried several versions of  constructing the generic ChartCollection (see the enclosed project: MainWindow cs file ) class:
- ChartCollection< List<double>, List<double>> d = new ChartCollection< List< double> , List<double>>(100);
This declaration does not compile
- ChartCollection< double, List<double>> d = new ChartCollection<  double , List<double>>(100);
This compiles, but crashes in the Append() call
- ChartCollection<double, double> d = new ChartCollection<double, double>(100);
This compiles but the Append() call only updates the first plot.
Does anyone have a solution to this relative simple question ??
(5,766 Views)
To display chart data for multiple plots, you can use multiple chart collections.
The easiest way to update your example project would be to use an array of chart collections:
    ChartCollection<double, double>[] d = new[] {
        new ChartCollection<double, double>(100),
    d[0].Append(t, s);
    d[1].Append(t, s1);
~ Paul H
(5,751 Views)
