CompactDaq AI with Visual Basic .NET
Here is the project without Excel, but now I have an error whose message I have attached as an image.  It happens with I try to execute Reader(0).ReadMultiSample
Programming Data Acquisition and Control in Measurement Studio and Labwindows/CVI
Message 31 of 115
(3,218 Views)
Hi Michael,
Hopefully, I have found the problem!  You are receiving the -200278 error because your timing mode is set to Finite, even though you are doing a Continuous acquisition.  This may be causing the slow acquisition rate as well.
Try this change, replace Finite with Continuous.
                Tasks(TaskCount).Timing.ConfigureSampleClock("", frm.numSampleRate.Value, SampleClockActiveEdge.Rising, _
                                                             SampleQuantityMode.FiniteSamples, frm.numSamples.Value)
Replace with
                                                             SampleQuantityMode.ContinuousSamples, frm.numSamples.Value)
Please let me know if this solves the problem!
Erik
Message 32 of 115
(3,207 Views)
Now I am getting "Attempting to read a sample that is no longer available."
Message 33 of 115
(3,203 Views)
Hey Michael,
I think you are getting error -200279, Attempted to read samples that are no longer available. The requested sample was previously available, but has since been overwritten.
This error indicates that the DAQ card acquired samples, placed them on the buffer, and that the samples were overwritten before your .NET code could read from the buffer.  The buffer size is determined by the number of samples input, we may want to increase that number.
What numbers are you using for your rate and number of samples?
Erik
Message 34 of 115
(3,202 Views)
200 S/s and 1 or 2 samples per channel.  I'd like to keep my loop time under 500 ms if possible.  I am happy with one reading as long is it isn't subject to noise.  It seems to run very close to our SCXI system which is taking 100 samples and averaging them.  If I increase the number of samples I want, won't it take longer to respond?  Should I just decrease my rate?
Message 35 of 115
(3,196 Views)
Hey Michael,
If your goal is 1 or 2 samples per second, why is your rate set to 200 S/s?  I think that you are correct in that the rate needs to be decreased to 1 or 2 S/s.  I would suggest trying 1 sample per channel and acquire at 2 S/s (2 Hz).  This way, your loop will take 500 ms and you shouldn't get any buffer problems.
Erik
Message 36 of 115
(3,181 Views)
Have you been able to get my software working on your computer?  The latest one with no excel reference.
Message 37 of 115
(3,178 Views)
Hi Michael,
I was able to get your code to run without error if I use 2 samples per channel and a rate of 2 S/s.  I am unsure where it writes to file though.
Erik
Message 38 of 115
(3,175 Views)
It's in bin\data where the application startup path is
Message 39 of 115
(3,172 Views)
Hi Michael,
I found the data file, it is attached.  I am still having trouble understanding your code.  It seems that no matter what I put in for the rate, it still samples at 1 S/s for me.
Erik
Message 40 of 115
(3,168 Views)
