Connecting to a custom device
I am considering purchasing Measurement studio for the purposes of creating a custom test instrument using an Arduino Due. I want to write the code on the instrument side in C (Atmel Studio)rather than in the Arduino environment.
I would like to connect to a simulated serial port on the PC via  FTDI .
In other words I quess it would be like simulated RS232
I would like to send serial commands to control Digital outputs, and Read Digital Inputs. I would also like to send analog data to implement a slow speed oscilloscope. Is this possible while still making use of all the great features of Measurement Studio?
Is there example code for a custom device with a serial interface?
Any help would be greatly appreciated
(3,242 Views)
Seems like it'd be fine to me.  I found this article which covers this in more detail.
http://www.ni.com/tutorial/4058/en/
I'd give that a read and see if it applies to you.
(3,213 Views)
Thanks for the link Dsun:smileyhappy!  If I am understanding it correctly my device would still need to have a driver that measurement studio could find. I am not familar with writing device drivers.
The way I had envisioned it working was to have my device exhange serial commands, handshaking, and data using some predefined standard.
Perhaps I could make it work using an existing driver if I new the exact communications protocol?
Is there anyone out there who has implemented a custom device using serial communications?
(3,203 Views)
