Controlling PXI-2501 Switches in C#
What is the best - prefered - way to control a PXI-2501/2503 Switch Matrix in C#.
I have only been able to find examples showing SCXI switching units. Is it done in the same way?
Code examples would be nice.
(4,257 Views)
I am assuming that the examples you are using are the DAQmx C# examples (Program Files\National Instruments\MeasurementStudio70\DotNET\Examples\DAQmx\Switches).
These examples work for all SCXI and PXI switches that are supported in DAQmx. NI-DAQ 7.1, the currently released version of NI-DAQ driver software, does not support PXI-2501/2503 under DAQmx. These modules will be supported in DAQmx in the next version of the driver.
(4,257 Views)
So when is the new version going to be available?
How can I control the PXI-2501/2503 switches in C# in the mean time?
(4,257 Views)
The new version of NI-DAQ will be available for download on the web on April 19th. This version will have DAQmx support for PXI-2501/2503.
(4,257 Views)
