Could not load file or assembly NationalInstruments.Common ... or one of its dependencies. The system cannot find the file specified.
Roberto,
Thanks for posting. It looks like you have done, in VisualStudio 2008,  "File -> New -> Project -> Web -> ASP.NET Web Application" to create this website. I was under the impression that you have created a web site, (by doing "File -> New -> Web Site -> ASP.NET Web Site").
I'll take a look at the project you have attached and get back to you if I find anything. Meanwhile, can you try creating a 'web site' and see if it works ?
-Mahesh
Message 11 of 13
(2,571 Views)
Mahesh,
Yes, my project is a "Web Application" due the reason explaned in this MSDN document: http://msdn.microsoft.com/en-us/library/aa730880(VS.80).aspx
I did the "web site" test but the result is exactly the same.
Also I try with a new web site in VS2005 instead of VS2008 but it produce the same blank page!
Roberto
Message 12 of 13
(2,567 Views)
Hello to everybodies
the problem was on the server of my provider!
This week I setup a virtual machine with Windows Server 2003 R2 Standard Edition + SP2 + II6 + ASP 2.0 + Framework 1.1, 2.0, 3.0 and 3.5
Then I copied my web application and now I can see the graph  !!!!
Thank you for your interest and precious suggestion
Regards
Roberto Bergo'
Message 13 of 13
(2,455 Views)
