Cursor.Plot and Cursor do not belong to the same graph.
when I set the Snapmode from an XYCursor to floating sometimes the Exception "Cursor.Plot and Cursor do not belong to the same graph." is thrown. The xycursor.Owner is equal to xycursor.Plot.Owner.
My workaround is, to catch the Exception an then to set the Snapmode to floating-> that works.
Best regards
Gerald
(4,736 Views)
I found this topic they received the same Exception.
Multiplot ScatterGraph - snap cursor to nearest point AND plot - NI Discussion Forums
http://forums.ni.com/t5/Measurement-Studio-for-NET/Multiplot-ScatterGraph-snap-cursor-to-nearest-poi...
Regards
(4,673 Views)
Hello.
Thank you for your answer. I can't find a solution for my problem in this topic and the bug with ID #102698 i can't find in any bugifxhistories of Measurementstudio.
I'm using MS2013.
Best regards
Gerald
(4,667 Views)
from what Snapmode are you moving to floating?
My you try using another Snapmode.
Interacting with Measurement Studio Graphs in Visual Basic - National Instruments
http://www.ni.com/example/2820/en/
Are there several Plots in your graph and how often does the error occure?
Regards
(4,513 Views)
