CwGraph, Colors and .Net
I'm trying to modify the colors of my graph.
Some parameters use the system.color library
like
Dim myColor As Color
Graph.BackColor = myColor.Black
but others require a unsigned 32 bit integer
like
Graph.Plots.Item(1).LineColor = 'some value'
what's the syntax for setting line/fill colors in .Net?
Curt
(6,289 Views)
The unsigned 32-bit integer is a Win32 color, so you can use the System.Drawing.ColorTranslator class's ToWin32 method to convert a System.Drawing.Color to an integer. To convert the integer to an unsigned integer, use Convert.ToUInt32. Here's an example:
Dim lineColor As Integer = ColorTranslator.ToWin32(Color.Red)
Graph.Plots.Item(1).LineColor = Convert.ToUInt32(lineColor)
- Elton
(6,289 Views)
