DACmx Configuration Export/Import with C#
Hi
Is it posible to export/import DACmx configuration via  C# .net ?
Best Regards
(3,850 Views)
Depends on what exactly you want to export. For Tasks/Channels/Scales/etc. (basically everything you can export from inside NI MAX as well) there are functions to do so. You can find documentation on them in the "Storage" section:
NI-DAQmx C Reference Help » NI-DAQmx C Functions » Advanced Functions » Storage
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
(3,824 Views)
I am looking for at function like the File-->Export/Import menu in NI MAX.
As I understand the functions under Storage they stores e.g. a task to MAX but not to a .nce file.
(3,810 Views)
Accepted by topic author Rasmussen
As far as I know DAQmx C API does not provide such a high-level function.
However there might be a way: LabVIEW has a VI to export the configuration of a target (including "localhost"): Export (VI) - NI System Configuration API 17.0 Help. See Import and Export a MAX Configuration Through LabVIEW for a bit more information. This VI is not much more than a wrapper of a dll's function:
You will find the corresponding header typically in C:\Program Files (x86)\National Instruments\Shared\CVI\include\nisyscfg.h. Do you think you will be able to use this dll to achieve what you are trying to do?
CLADMSD
(3,788 Views)
Thanks ikaiser
I will try to look into your suggestion. It sounds promissing.
(3,764 Views)
