DAQmx.Device problem
Trying C# from Delphi and early days yet. (Visual Studio C# 2005 Express and NI-DAQ8.1)
My understanding, from looking at the help files is that when you have
NationalInstruments.DAQmx.Device.
there would then be a list of associated properties and methods, but all I see are Equals and Reference Equals in the autocomplete list.
I have my test program working to show the devices
private void button1_Click(object sender, EventArgs e)
object devarray;
int devcount;
devcount = NationalInstruments.DAQmx.DaqSystem.Local.Devices.Length;
MessageBox.Show("Devices " + devcount.ToString());
for (int i = 0; i <= devcount - 1; i++)
devarray = NationalInstruments.DAQmx.DaqSystem.Local.Devices.GetValue(i);
MessageBox.Show(devarray.ToString());
// NationalInstruments.DAQmx.Device. ---->>>????
so I assume I have loaded everything I need to ( the dlls from the DotNet directory)
Any ideas anyone
Andy
(3,568 Views)
NI.DAQmx.Device is a class, not a property. You need to set it up as follows:
using NationalInstruments.DAQmx; //namespace at the top
Device test = DaqSystem.Local.LoadDevice("\\Dev1");
DeviceBusTypebus = test.BusType; //for example
Bilal Durrani
NI
(3,566 Views)
OK Bilal
Got it going now (it didn't like the \\ in \\Dev1 btw.)
Andy
(3,557 Views)
