DAQmx fft measurement
we want to test a usb-6008 with DAQmx driver and measurement studio for calculating fft of signal.
do you have a programming tutorial step by step description?Smiley Sad
(5,459 Views)
We don't have any setp by step examples of how to do this, but there are C# and VB.NET examples that show you how to acquire an analog input signal continuously. Then all you need to do is use the Measurements.AmplitudePhaseSpectrum() function to give you the results of the fft of the acquired signal. You will need DAQmx 7.5 to use the USB devices with DAQmx. See the DAQmx examples under ..\MeasurementStudio2003\DotNET\Examples
Bilal Durrani
NI
(5,446 Views)
Hi
Thanks for quick response.
Unfortunately, i could not find the
NationalInstruments.Analysis.SpectralMeasurements.Measurements.AmplitudePhaseSpectrum
function under Measurement Studio DAQmx examples.
pls check our codes, how can we use that function.
have you got any similar codes?
Private taskRunning As Boolean
Private myTask As Task
Private analogInReader As AnalogMultiChannelReader
Private analogCallback As AsyncCallback
Private data As Double(,)
Private Sub btnStart_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnStop.Click
     Try
taskRunning = True
myTask = New Task("aiTask")
myTask.AIChannels.CreateVoltageChannel(Dev1/ai0, "Voltage", AITerminalConfiguration.Differential, Convert.ToDouble(-20), Convert.ToDouble(20), AIVoltageUnits.Volts)
       myTask.Timing.ConfigureSampleClock("", Convert.ToDouble(1000), SampleClockActiveEdge.Rising, SampleQuantityMode.FiniteSamples, 256)
       myTask.Control(TaskAction.Verify)
       analogInReader =
New AnalogMultiChannelReader(myTask.Stream)
       analogInReader.SynchronizingObject =
Me
       analogCallback = New AsyncCallback(AddressOf AnalogInCallback)
        analogInReader.BeginReadMultiSample(Convert.ToInt32(numChannel.Text), analogCallback,
Nothing)
Catch exception As DaqException
      MessageBox.Show(exception.Message)
      taskRunning =
False
      myTask.Dispose()
End Try
End Sub
Private Sub AnalogInCallback(ByVal ar As IAsyncResult)
Try
If taskRunning = True Then
data = analogInReader.EndReadMultiSample(ar)
            WaveformGraph1.PlotYMultiple(data)
            analogInReader.BeginReadMultiSample(Convert.ToInt32(Convert.ToDouble(numChannel.Text)), analogCallback, Nothing)
End If
Catch ex As DaqException
MessageBox.Show(ex.Message)
taskRunning = False
myTask.Dispose()
btnStop.Enabled = False
btnStart.Enabled = True
End Try
End Sub
Message Edited by Oguz on 08-15-2005 09:28 AM
Message Edited by Oguz on 08-15-2005 09:31 AM
(5,447 Views)
Hi Oguz,
I believe that Bilal meant that there were examples for Continuous Analog Input, not specifically for FFTs.
Another point of clarification is that the Measurments.AmplitudePhaseSpectrum Method is only included in the Enterprise Edition of Measurement Studio.
You can find a description of the Measurements.AmplitudePhaseSpectrum Method by navigating to:
Start >> All Programs >> National Instruments >> Measurement Studio 7.1 for VS .NET 2003 >> Measurement Studio Documentation
Then select "Measurement Studio" under the Filter pull down.
Now navigate the help tree to
"NI Measurment Studio Help >> NI Measurement Studio .NET Class Library >> Reference >> National Instruments.Analysis.SpectralMeasurements >> Measurements Class >> Methods >> AmplitudePhaseSpectrum Method"
Here is the help file decription:
Calculates the single-sided, scaled amplitude spectrum magnitude and amplitude spectrum phase of a real, time-domain signal.
[Visual Basic]
Public Shared Sub AmplitudePhaseSpectrum( _
   ByVal signal As Double(), _
   ByVal unWrap As Boolean, _
   ByVal dt As Double, _
   ByRef amplitudeSpectrum As Double(), _
   ByRef phaseSpectrum As Double(), _
   ByRef df As Double _
[C#]
public static void AmplitudePhaseSpectrum(
   double[] signal,
   bool unWrap,
   double dt,
   out double[] amplitudeSpectrum,
   out double[] phaseSpectrum,
   out double df
Hope this helps Oguz, have a good one!
Dan Weiland
Dan Weiland
(5,423 Views)
Thanks DWeiland,
i am a new starter to measurement studio.
i found function but is there an example showing how to use it?
(5,418 Views)
Hi Oguz,
There aren't any examples that use that function explicitly, but the example found here:
C:\Program Files\National Instruments\MeasurementStudioVS2003\DotNET\Examples\Analysis\PowerFrequencyEstimator
uses the same Measurements class, so you may be able to get started there.
Here is a slightly more detailed description of the function parameters, as described in the Measurement Studio help file.
Parameters
signal
The input, time-domain signal, usually in volts. At least three cycles of the signal must be contained in the time-domain record for analysis and estimates based on this spectrum to be valid.
unWrap
The input that decides if the phase is unwrapped. If set to true, it enables phase unwrapping on the output phase, phaseSpectrum. If set to false, the method does not unwrap the output phase.
dt
The sample period of the time-domain signal, usually in seconds. dt is also 1/fs where fs is the sampling frequency of the time-domain signal.
amplitudeSpectrum
The single-sided amplitude spectrum magnitude. If the input signal is in volts, this value is in volts rms.
phaseSpectrum
The single-sided amplitude spectrum phase in radians.
df
The line frequency interval of the power spectrum. If dt is in seconds, this value is in hertz.
Dan Weiland
Dan Weiland
(5,409 Views)
