DAQmx with C# scale and calibration
Hi here,
I'm currently developping a data acquisition application and I have some troubles.. I'm using DAQmx driver in C# without Measurement Studio.
I've read the examples with the DAQmx driver but I don't find what I want..
So, in my system I have 6 sensors, and I all value I get is in Volt. So what I want is to get the voltage value and convert it into bar for example. I tried to understand the custumScale but i'm a little bit confused right now..
I have created a task, and a channel for each sensor.
Here is what I have for pressure :
 myTask.AIChannels.CreateVoltageChannel("Dev1/ai2", "HautePression",
                            (AITerminalConfiguration)(-1), 0, 10, AIVoltageUnits.Volts);
Then I would like to calibrate these sensors, I know I would use a linear law, take a low reference value and a high reference value, ok, but how do I apply the gain and the offset value calculate ? Or is there another way to do ?
I hope I've been clear enough.
Thank you,
Paul
(6,118 Views)
These links could be useful for you:
Let me know if you have specifics questions.
http://digital.ni.com/public.nsf/allkb/0464919A11C092E386256D800079C3BB
https://decibel.ni.com/content/docs/DOC-3706
http://digital.ni.com/public.nsf/allkb/3F6558112FD2C776862575B5004F7F87?OpenDocument
Regards
Samuel G. | GEMESIS
Certified LabVIEW Architect
Certified TestStand Developer
GEMESIS.EU
(6,013 Views)
First, thank you for your answer. I have already read those links, and I think I'm missing something..
Moreover, this documentation doesn't explain to me how to do it programmaticaly..
So do I have to use Measurement and Automation Explorer (MAX) to create my task, my channels and my scales and then find a way to load the task in my program ? Or should I do everything in C# ?
In your last link, it explain how do I make a custom scale, but I still have to calculate the m and the b in the equation y = mx + b ?
And in the first link there is this sentence : "NI-DAQmx includes built-in support for many of the most common transducers, sensors, and actuators." ; I'm currently using common sensors, so I'm a bit confused about what I have to do...
(6,010 Views)
