Daqmx ReadMultiSample - always old values in buffer
Hi!
I want to read in a given period of time, 20 samples from my 6025E.
I configured my task like this:
In the constructor:
this.KraftT.AIChannels.CreateVoltageChannel("Dev1/ai0","aiChannel",AITerminalConfiguration.Differential,0,10.0, AIVoltageUnits.Volts);
this.KraftT.Timing.ConfigureSampleClock("",this.konfig.100,SampleClockActiveEdge.Rising,SampleQuantityMode.ContinuousSamples);
this.KraftC = new AnalogSingleChannelReader(this.KraftT.Stream);
analogCallback = new AsyncCallback(AnalogInCallback);
this.KraftT.Start();
In the Callback:
this.m_NICallback(NationalInstruments.Analysis.Math.Statistics.Mean(this.KraftC.EndReadMultiSample(ar)));
In the called function:
return NationalInstrume
nts.Analysis.Math.Statistics.Mean(this.KraftC.ReadMultiSample(20));
My problem:
If I call my function just one time, I get the real value. The next values are all stored in the buffer, and when the voltage is in real higher, I only read the "old-values" which are stored in the buffer.
So I need any buffer - clear method, before calling my function, because I only need the actual values.
Can I reduce the buffer size to solve the problem, or what can I do ?
Please write back soon.!
Klaus
(3,711 Views)
Klaus:
I just answered a very similar (same?) question at the following URL
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=50650000000800000058EF0000&USEARCHCONTEXT_CATEGORY_0=_342_%24_7_&USEARCHCONTEXT_CATEGORY_S=0&UCATEGORY_0=_342_%24_7_&UCATEGORY_S=0
If this doesn't help you, please let me know.
Chris W
NI .NET DAQmx Team
(3,711 Views)
