Detect GraphInteractionPalette Click
I'm wondering if there is a way to detect when a GraphInteractionPalette button is clicked. I tried attaching a MouseDown/MouseUp event handler to the GraphInteractionPalette but that did not fire, I'm guessing because I would need to add the event handler to the actual button inside the palette.
Ideally I could detect which button on the palette was clicked, e.g. ZoomToFit.
Thanks in advance.
(6,646 Views)
Buttons handle the MouseDown and MouseUp events itself, which you can see by attaching the events to a stand-alone button outside of any other control. From these events, it raises the Click routed event, which you can listen to on the interaction palette:
    <ni:GraphInteractionPalette Button.Click="OnButtonClicked" />
The content of the clicked button will be the associated graph interaction (or a string for the "zoom to fit" option):
    private void OnButtonClicked( object sender, RoutedEventArgs e ) {
        var button = e.OriginalSource as ButtonBase;
        var interaction = button != null ? button.Content as GraphInteraction : null;
~ Paul H
(6,625 Views)
Thanks, that's what I needed.
(6,619 Views)
Just wanted to let you know that Measurement Studio 2019 added the GraphInteractionPalette.InteractionSelected event to support custom handling of interaction buttons.
~ Paul H
(2,974 Views)
