Detect TTL signal using configured acquisition
I am running the same solution with my own modification. I have added a waveform for incoming data and then I have done some processing on the data. Please see the attached screenshot and help me improve the acquisition time. Thank you for your help.
Message 21 of 30
(2,733 Views)
Hi Paritosh,
We need to estabolish a base for what you are getting for actual sample rate. When you run the example as it is, what actual sample rate do you get?
Travis Ann
Customer Education Product Marketing Manager
Message 22 of 30
(2,726 Views)
I am giving the same sampling rate in both cases. In the example as it is and in my modified program the parameters are same. So how to find what sampling rate I am getting?
Message 23 of 30
(2,722 Views)
Hi Paritosh,
In the example that I talked about before, it returns your actual sample rate. I've highlighted it below with an arrow. What is returned when you run it?
Travis Ann
Message 24 of 30
(2,714 Views)
It returns the sample value that is in the minimum sample rate. i.e. 1e6. If i change the minimum sample rate, the actual sample rate also changes to the same value...
Message 25 of 30
(2,712 Views)
Hi Paritosh,
Since you are getting the same actual sample rate as minimum rate in the example, it would be good to implement that same functionality in your code, so that we can see what same you get for actual sample rate when you run your code. That way, we have a base for how far off your desired sample rate is from your actual rate.
Travis Ann
Message 26 of 30
(2,707 Views)
What do you mean by implementing the same functionality in the code? I am using the same code with modifications, but still the actual sample rate is shown similar to the default program but the data acquistion rate is too slow. Can u check my code that I posted before?
Message 27 of 30
(2,702 Views)
Hi Paritosh,
What is your actual data acquisition rate? How are you measuring? Also, when you run the example without your modifications, what data acquisition rate to you achieve?
Travis Ann
Message 28 of 30
(2,694 Views)
I am giving 1 KHz input to the digitizer. I don't know the exact way to measure the acquisition rate. Can u suggest me any way?
Message 29 of 30
(2,690 Views)
Hi Paritosh,
Since you are not measuring the acquisition rate, what are you seeing that is giving you the impression that it is too slow? Will you please explain what you are observing that makes you think that your measurement is too slow? Can you post screenshots of Soft Front Panel? Are you getting an error of some kind? Is it that you aren't acquiring all of your data?
Have you tried using the example code? If you are seeing some type of delay with only your code and not the examples, it would be to your advantage to find the differences between your code and our examples and explore those differences.
Let me know what you are seeing that leads you to think that the data acquisition rate is too slow, and I will try to provide you with some advice.
Kind Regards,
Travis Ann
Message 30 of 30
(2,678 Views)
