Difference between Winform and WPF zoom management
After loading a plot in a WPF graph and zooming, if we change programmatically the axis range, the zoom manager loses all its information :
UndoZoomPan, ResetZoomPan, etc. doesn't works.
For information, with a WinForm graph the zoom manager keeps all information and continue to work successfully.
Is it a normal behavior for WPF graph?
O. DANIERE
(6,273 Views)
This is the expected behavior for the current implementation of undo history in the WPF graph: when scales are changed outside of one of the Interactions on the graph, the undo history is reset. I have created a task to try and match the behavior of the Windows Forms graphs in WPF.
If you need more control over interaction history in your current application, you can disable undo history in the graph by setting the InteractionHistoryCount property to zero, and listen to the RangeChanged event on the scales to save a history of their values.
~ Paul H
(6,256 Views)
Just wanted to let you know this issue (#403056) was fixed in the Measurement Studio 2015 release.
~ Paul H
(4,707 Views)
