Different Y Axis Range in WaveformGraph
I am trying in C# to create a WaveformGraph with 2 y axis with different ranges.
On the first  Y Axis I have a range from 0 to 80 and on the second I have a range from -127 to 127.
I created the two different Y Axis and set the range accordingly and they show up correctly next to the plot.
Then I created two waveformPlots.  One I set the waveformPlot.YAxis.Range to (-127,127) and the other waveformPlot to (0, 80).  The problem is when I draw the plot the total range for the plot gets change to (-127, 127) and my (0, 80) plot gets shifted up to be in the center of the waveform.  I would like this plot to stay down at the bottom of the graph to match the Axis that I created.
I can normalize the values but my users use the  Tool tips to get the measurement results and those would no longer be valid if I subtracted 127 from the values in the second waveform.
(4,231 Views)
Accepted by topic author UmmGooD
Okay I managed to figure this out for myself.  In error I had the following code:
waveformPlot1.Yaxis.Range = new Range(0,  80);
waveformPlot2.Yaxis.Range = new Range(-127, 127);
Instead I used the two y axis I already had used.
waveformPlot1.Yaxis = yAxis1
waveformPlot2.Yaxis = yAxis2
(4,219 Views)
Hi UmmGooD,
I was able to build something similar to what you are describing, and I think you just need to make sure you set both of your yaxis objects to have a fixed range.  If this is not set, then the axis will change depending on the data in the graph.   Please see the attached example to look at my implementation.
(4,217 Views)
