Digital Filters and continues Datastreams?
During a long period of data acquisition I want to inform the user with intermediate results.
But I have to implement a LowpassFilter.
I couldn't find any information how to use Digital Filters of NationalInstruments.Analysis.DSP.Filters
with continues Datastreams.
Can anybody give me a hint ?
(3,687 Views)
hello heinz,
can you provide further information on the application, that you use?
do you continuous acquire blocks of data?
means intermediate results, that you present constant block of data or that you need the result for the whole time you acuired?
regards,
robert h
national instruments
(3,675 Views)
Hello robert,
thank you very much for your reply and sorry for the late reaction.
My application runs 24 hours a day an acquires data with a sample rate of 50kHz.
This data will be transfered in blocks of about 10k every 200ms to a low pass filter and then to a display to present intermediate results.  But the settling time of the filter is longer than the update frequency of the display.
In that case I need the possibility to give the filter an initial value. But I couldn't find any related method.
regards,
heinz
(3,651 Views)
hello heinz,
does this mean, that the time, for one filter operation with one of your packets takes longer as you have for displaying the result on the screen?
which filter do you use?
could you provide a code snippet?
regards,
robert h
(3,642 Views)
hello robert,
I think I found the problem. I used the filter as a traditional function.
      Private IStream() As Double
      Private QStream() As Double
      Private Filter As Filters.ButterworthBandpassFilter
      Filter = New Filters.ButterworthLowpassFilter(cFilterOrder, nSampleRate, nCutOffFreq)
     IStream = Filter.FilterData(IStream)
     QStream = Filter.FilterData(QStream)
I used the same filter for 2 different data streams
But the filter is an object  with its own history, so
         Private Filter1 As Filters.ButterworthBandpassFilter
         Private Filter2 As Filters.ButterworthBandpassFilter
      Filter1 = New Filters.ButterworthLowpassFilter(cFilterOrder, nSampleRate, nCutOffFreq)
      Filter2 = New Filters.ButterworthLowpassFilter(cFilterOrder, nSampleRate, nCutOffFreq)
     IStream = Filter1.FilterData(IStream)
     QStream = Filter2.FilterData(QStream)
     Now it seems to work!
Thank you very much
Heinz
Message Edited by heinzS on 08-31-2005 07:44 AM
(3,635 Views)
