07-16-2007 04:32 PM
07-17-2007 10:18 PM
Hi John,
To answer your question, you are not able to internally route your analog input
to another terminal. Would you be able to tell me a little more about your
application? Do you need to route internally or would routing the signals
externally be acceptable?
07-18-2007 06:51 AM
My experiment requires acquiring 64 voltage channels, but I'd like the ability both to see one of these channels on an oscilloscope and hear it on audio. Routing externally is acceptable, just not preferred. Are there any prepackaged devices for this? Or would I have to make my own PCB? Currently, I'm sending one the channels to analog out post-digitization, which makes the signal look pretty choppy on the oscilloscope.
07-19-2007 09:05 PM
