Discrete ticks
Here is a complete implementation of the custom divisions mode, which wraps another mode to add the duplicating behavior. Just pass the interval mode as the constructor parameter for the custom mode:
    AxisX.MajorDivisions.Mode = new CustomDivisionsMode(
        RangeDivisionsMode.CreateIntervalMode(0, AxisX.Range.Maximum > 20 ? Math.Round( AxisX.Range.Maximum / 10 ) : 1)
~ Paul H
Message 11 of 16
(3,699 Views)
Thanks! This seems to work.
But I think that creating new modes all the time is not such a good idea. How can I update this class to support dynamic interval change?
Snippet
void AxisX_RangeChanged(object sender, EventArgs e)
            if ((string)editXMin.MinValue == "0" && AxisX.Range.Minimum < 0)
                AxisX.Range = new Range<double>(0, AxisX.Range.Maximum - AxisX.Range.Minimum);
            RaisePropertyChanged(new string[] { "AxisXMin""AxisXMax" });
            if (AxisX.MajorDivisions.Mode.Name == "Interval")
                AxisX.MajorDivisions.Mode = new CustomDivisionsModeForInterval(RangeDivisionsMode.CreateIntervalMode(0, AxisX.Range.Maximum - AxisX.Range.Minimum > 20 ? Math.Round((AxisX.Range.Maximum - AxisX.Range.Minimum) / 10) : 1));
Message 12 of 16
(3,697 Views)
You could update the custom divisions mode to remove the inner mode parameter, and instead create the two interval modes ahead of time. Based on the range of the data mapper passed in to GetDivisions, you could choose which interval mode to use as needed (instead of assigning a new mode in the range change handler). That way you would only need to assign Mode once.
~ Paul H
Message 13 of 16
(3,694 Views)
I've lost you here. How does it help me to deal with axis updates due to zoom? This requires a lot of different intervals, not just two.
Message 14 of 16
(3,686 Views)
I was just referring to how you could update the existing code, which lists only two intervals (1 when Maximum is below 20, and Round( Maximum / 10 ) otherwise). You are not limited to those particular values in your implementation; GetDivisions can return any values you want based on the current range.
~ Paul H
Message 15 of 16
(3,680 Views)
Just wanted to let you know we have fixed the grid line alignment issue in the Measurement Studio 2015 release.
~ Paul H
Message 16 of 16
(2,956 Views)
