Does anyone know how to draw the graph like this ?
I am using Does anyone know how to draw the graph like this ? Should i use Scatter Graph or intensityGraph ?
If anyone knows , please tell me . I already google many website , but there is still no help for me .
PS. I am using Measurement Studio 2010
https://www.google.com.tw/search?q=%E5%85%89%E8%AD%9C%E5%9C%96&biw=1920&bih=955&source=lnms&tbm=isch...
(4,982 Views)
There is no spectrum graph in LabVIEW or Measurement Studio. You can make it with intensity graph but need sort of modification as following issue listed.
1. Scaling your data based on Y-value to fit the amplitude. Because intensity graphs only accept x-y coordinate(2-D), you should modify your data (I guess it is waveform graph style(1-D array) into the type of intesity graphs, filling the bar depending on Y-value each x.
2. Modifying your data with different intensity value depending on different x coordinate so that you could show different color with different x coordinate.
3. Adding color to graph: In LabVIEW, we could add color to a intensity graph as follows.
http://digital.ni.com/public.nsf/allkb/1ADFF221E27F5B5886256E6F007C7B58
Therefore, I think it is possible to do so in Measurement studio. I found some information with it but I am not sure if it is the class/method we want.
 http://forums.ni.com/t5/Measurement-Studio-for-NET/Change-the-Color-Map-of-the-Intensity-Graph-at-Ru...
You can take a glance or search it by your own.
(4,951 Views)
Thanks for your reply , I am trying @"@
(4,882 Views)
