10-01-2015 01:49 PM
I am building a .NET application that will be installed onto a Windows 7 Embedded machine. I will be using an Ethernet cDAQ 9184. The chassis will have an NI 9205 module installed for sure, but possibly other different modules. What software and drivers do I require to be installed on the Windows machine? I have the NI Device Drivers disk (August 2015) but there are a lot of drivers on this disk and I want to be sure I'm installing only what I require.
10-02-2015 01:23 PM
Hi DM@Means,
You definitely need to install the DAQmx driver. What other drivers come on the disk that you currently have?
Aaron F.
Applications Engineering
10-02-2015 01:33 PM
There are 140 device drivers on this disk.
10-02-2015 03:37 PM
10-06-2015 06:58 AM
Thanks for the feedback. Will do.
