Exception when plotting NaN values
I have a real-time graph which should display gaps from time to time. I tried to use NaN values but I am getting System.OverflowException after application runs for some time. Attached the sample project that demonstrates the problem.
Thanks.
(4,540 Views)
I ran your project and noticed that the plot's ProcessSpecialValues property was set to false. Set the plot's ProcessSpecialValues property to true and your application will behave correctly.
ProcessSpecialValues means the plot will process NaN and Infinity values. GDI+ by itself cannot handle NaN and Infinity values.
Brock
(4,532 Views)
The problem is that you do not have the ProcessSpecialValues property on the plot set to true. The plot has to perform a lot of extra processing to handle NaN and +/-Infinity values, which can have a negative impact on performance. ProcessSpecialValues lets you choose if you want to take the performance hit. Most applications do not work with NaN and +/-Infinity values, so the default value is false in the interest of performance. For more information, see the Knowledge Base article "Why Does Plotting NaN or Infinity Values Generate an Exception Using .NET Graph Controls?" [broken link removed].
- Elton
(4,530 Views)
Here [broken link removed; article no longer available] is the external link for the knowledgebase that Elton mentioned.
Bilal Durrani
NI
(4,514 Views)
Oops ... sorry for posting an internal link. I thought it was an external link. Sorry for the confusion.
- Elton
(4,511 Views)
