Formula Waveform
 Where can I find a Measurement Studio C# function to perform the same operation as the "Formula Waveform" VI in labview?
Thank you.
(3,402 Views)
Hi MDKF,
I've got good news and bad news. The bad news is that there isn't a C# function that performs the same operation as "Formula Waveform" Vi in LabVIEW.
The good news is that it is relativity easily to graph waveforms based on a function. This particular function is implemented in LabVIEW because it's difficult to graph waveforms due to the inherent structure of LabVIEW. With C#, all you have to do is to generate an array that contains all the vales of your math function. Then plot the array into a graph. Below is a Visual Studio link that explains how to create an array in C#.
http://msdn.microsoft.com/en-us/library/dbcwkdwa%28v=vs.80%29.aspx
I hope this helps.
Josh L.
(3,390 Views)
