Get any/all VISA-USB Addresses
and you might want to remove the reference to IVI.Visa
Message 11 of 24
(2,716 Views)
Thanks, but the resource string
"USB0::0x05E6::0x2601::4018686::INSTR"
is precisely what I would like to retrieve. After retrieving the resource string, I can open communication with the device.
Message 12 of 24
(2,711 Views)
Sorry , I missed that.
Here's some code I wrote a while ago. It's in C# but you should be able to translate it to VB.
I don't have any hardware at my desk so I didn't test it, but I think it works.
Curt
private bool FindUSBResources()
            HardwareInterfaceType intType;
            short intNum;
            try
                string[] resources = ResourceManager.GetLocalManager().FindResources("?*");
                Trace.WriteLine("FindUSB " + resources.Length);
                //string[] resources = ResourceManager.GetLocalManager().FindResources(m_resourcename );
                if (resources.Length > 0)
                    foreach (string s in resources)
                        ResourceManager.GetLocalManager().ParseResource(s, out intType, out intNum);
                        if (s.Contains(m_resourcename) == true)
                            m_sessiontype = 0;
                            return true;
                else
                    return false;
                return false;
            catch (VisaException vex)
                Trace.WriteLine("Visa: " + vex.Message.ToString());
                return false;
            catch (Exception ex)
                Trace.WriteLine(ex.Message.ToString());
                return false;
Message 13 of 24
(2,703 Views)
In the line: ResourceManager.GetLocalManager().FindResources("?*")
 I get an error saying: GetLocalManager is not a member of ResourceManager
ResourceManager is OK as it is a member of Imports NationalInstruments.Visa
Message 14 of 24
(2,694 Views)
Hi
This code worked for me.
Here's the output. I don't have any instruments connected.
0 ASRL1::INSTR
1 ASRL10::INSTR
2 GPIB0::INTFC
GetLocalManager() is listed here...
http://zone.ni.com/reference/en-XX/help/370627F-01/mstudiowebhelp/html/1ab541cb/
Curt
   Private Sub Button2_Click(sender As Object, e As EventArgs) Handles Button2.Click
        Dim intType As HardwareInterfaceType
        Dim intNum As Short
        Dim j As Integer
        Try
            Dim resources As String()
            For j = 0 To resources.Length - 1
                Debug.WriteLine(j.ToString() + " " + resources(j))
        Catch ex As Exception
        End Try
    End Sub
Message 15 of 24
(2,689 Views)
... ResourceManager.GetLocalManager...  doesn't work for me. Are you using VisaNS.dll for reference?  I've got : nationalinstruments.Visa and IVI.Visa referenced. I can't find VisaNS.
imports:
Imports Ivi.Visa
Message 16 of 24
(2,685 Views)
Hey,
I have
Imports NationalInstruments.VisaNS
The Reference I have is Ver 13.0.35.190
The version of NI-VISA listed in MAX is 14.0.1
Curt
Message 17 of 24
(2,683 Views)
Here's what I have. I don't have NationalInstruments.VisaNS and I don't know how to get it.
Message 18 of 24
(2,679 Views)
Look in the NI folder under C:\Program Files (x86). It should be in one of the Measurement Studio folders.
Mine is located at
C:\Program Files (x86)\National Instruments\MeasurementStudioVS2008\DotNET\Assemblies\Current\NationalInstruments.VisaNS.dll
If you can't find it, you might have to reinstall and select the option to install support for .NET
Curt
Message 19 of 24
(2,667 Views)
Well I guess that's the problem. I don't have Measurement Studio. Do I need to buy it?
Message 20 of 24
(2,659 Views)
