Get handle to existing task defined in MAX
LabVIEW 8.2.1 installed
NI-DAQmx 8.5 installed
Measurement Studio Not installed
Using C# .Net, is there a method for obtaining a handle to a task which has already been defined in the Measurement and Automation explorer (MAX)?
It seems like a lot of duplicated effort to programatically redefine a task that has already been defined.
Thanks!
Rick
(3,959 Views)
Hi Rick,
There is a DaqSystem Class that contains methods that allow you to access tasks, scales, and global channels stored in Measurement & Automation Explorer (MAX).  If you wanted to load a task from MAX in C#, you could say:
Task
t = DaqSystem.Local.LoadTask("mySavedTaskName");
Hope this helps!
Best Regards,
Jonathan N.
(3,938 Views)
Thanks!  That's exactly what I was looking for!
Rick
(3,932 Views)
So what if I wanted to do the same in matlab? Is that even possible?
H
(3,276 Views)
