Hiding the Axis values, but showing the ticks on a waveformplot
Hi all,
I have a waveformplot that is displaying data.  I want to display the X-Axis ticks, but not the values of those ticks.  Is there a switch to accomplish that?
EG
my divisions are every 5 units.  I do not want the numbers 5, 10, 15, ... to appear.  Just the division lines and the caption.
Thanks for any help
~sinisa
(3,241 Views)
Sinista,
I am not sure if you are using the .NET or ActiveX control, but since you refer to a Waveform, I will assume .NET.
If you right click on your graph, choose "Edit X Axis...", then under "Divisions" you should have the property MajorDivisions.LabelVisible.  If you set that property to False, the numbers on your axis should disappear.
Josh W. | National Instruments | Applications Engineering
Josh W.
Certified TestStand Architect
Formerly blue
(3,231 Views)
