How acquire scaled and unscaled data with .net ?
I acquire continuous data with asynchronous method BeginReadMultiSample. I initialize a new Task and a new AIChannel with method CreateVoltageChannel.
Actually, I acquire unscaled data but I would like to scale this data. I've read than it exists Scale class.
How do I use this class ? With a task ? With a channel ?
I've read than it exists CreateVoltageChannel constructor with scale argument.
Must I create two channels ?
Code:
public class acquisition {
public acquisition (){
// New Task
m_AITask = new Task(nameTask);
                    // Création du canal Analog Input
                    m_AITask.AIChannels.CreateVoltageChannel("Dev1/ai0",
                                                            AITerminalConfiguration.Differential,
                                                            -10.0, 10.0,
                                                            AIVoltageUnits.Volts);
                    // Configuration de l'échantillonage
                    m_AITask.Timing.ConfigureSampleClock("",
                                                    1000,
                                                    SampleClockActiveEdge.Rising,
                                                    SampleQuantityMode.ContinuousSamples,
                                                    1000);
                    // Vérification de la tâche crée
                    m_AITask.Control(TaskAction.Verify);
                    // Déclaration du type de lecture
                    m_Reader = new AnalogMultiChannelReader(m_AITask.Stream);
                    // Synchronisation (nécessaire qu'avec .NET 2.0)
                    m_Reader.SynchronizeCallbacks = true;
public void ReadMultiData()
            if (m_TaskRunning)
                try
                    // begin an asynchronous analog input operation
                    m_Reader.BeginReadMultiSample(m_AcquiParametre.SamplesPerChannel,
                                            new AsyncCallback(ReadCallBack), null);
                catch (DaqException ex)
                    m_TaskRunning = false;
                    m_AITask.Dispose();
                    Console.WriteLine("Erreur");
Thanks.
(4,041 Views)
Please precise me what you mean by "unscaled data". Do you get an integer instead of a float? Or do you get your value in volts instead of volts?
If you want to retrieve the values in a physical unit instead if volts, then you can create a new scale from "Measurement & Automation Explorer" and specify this scale in the CreateVoltageChannel() method.
(4,014 Views)
Term "unscaled data" means "data in Volts".
I would like to acquire data in Volts and scaled data.
(3,996 Views)
Sorry for the delay, but i suppose that you have found by yourself that you can set the units in volts when you create a scale in MAX.
(3,919 Views)
Bonjour,
je fais de l'acquisition de données avec NiDAQmx. Les données lues sont en Volts. Je dois mettre à l'échelle ces données et j'aurais aimé utiliser le PolynomeScale. Comment puis-je faire pour obtenir les données en Volts et les données mises à l'échelle ?
Merci d'avance.
Zoax
Message Edité par zoaax le 10-11-2006 10:31 AM
(3,822 Views)
