How can I create a rectangle selection tool inside an intensity graph? I need to be able to select several plots with a rubber band like selector inside of an intensity graph on my C# Form
How can I create a  focus rectangle or rubber band rectangle selection tool inside an intensity graph?
I need to be able to select several plots with a rubber band like selector (rectangle) from inside of an intensity graph on my C# Form.
This selector would give me the (x,y) of a 3X3 or 4X4 area of plots from an existing graph of say 64X64 plots.
Currently I have a cursor which only gives me a single plot for (x,y).
(6,816 Views)
Hi bill_donahue,
Do you want to get all the individual (X,Y) values inside of a rectangle that you specify? Or did you want to zoom into the rectangular area selected? For the latter, you can use ZoomXY and detect where the mouse was clicked and released to figure out the coordinate parameters.
Humphrey H.
(6,792 Views)
Humphrey,
     I need to get all of the (X,Y) plot data inside of a drawn rectangle. My systems engineer wants to be able to select an area from a waveform graph, or intensity graph.
So it would be similar to the Zoom rectangle but instead of zooming, my C# application that uses Measurement Studio 2013, would be able to manipulate the individual
(X,Y) elements. Are there any native features that will do this, I was thinking that I might have to use two cursors.
Bill
(6,780 Views)
Bill,
I don't believe there is a native function for this. You can probably extract the data after finding the X and Y range of the selected area (using the cursors or the min/max of the axes).
Humphrey H.
(6,766 Views)
Humphrey,
     How do I get a "selected area" ? That is my issue, how can I select an area from a graph, and how can I tell what that selected area is?
Bill
(6,755 Views)
