How can I store recorded Data in an array? (C#)
Hello everybody, I´m a freshman in programming, so it's probably an easy answer for you guys. I'm using Microsoft Visual Studio 2005 and C# together with the Measurement Studio 2008. My Hardware: NI 6036E I would like to have an analog output and the opportunity to measure a signal simultaneously. I used the wizard and it works pretty fine. I was also able to add some code in order to get my desired signal type. Now my problem: I am also able to record a signal via the wizard, but I just see it on the waveformgraph. I would like to store this signal in an array in order to conduct an FFT. How can a store this signal? Thanks for your help! I appreciate it! Heiko
(5,206 Views)
Heiko,
You can create an array of type AnalogWaveform<double>[]. You can then save the acquired data to this value.
-Adri
Adri Kruger
LabVIEW Product Marketing
(5,200 Views)
Thanks for the hint! It seems to work. But now I have trouble with the FFT. I’m using the following code:
AnalogWaveform<double>[] wf=e.GetData();
waveformGraphInputSignal.PlotWaveforms(wf);
ComplexDouble[] fftOutput= NationalInstruments.Analysis.Dsp.Transforms.RealFft(wf);
When I do it like this, I'll get the following error message: “Cannot convert from ‘NationalInstruments.AnalogWaveform<double>[] to ‘double[]’” I understand the error message but how can I solve the problem? Thanks again!
(5,184 Views)
Accepted by topic author okeih
I found it out myself:-)
double[] recordedData = wf[0].GetRawData();
ComplexDouble[] fftOutput = NationalInstruments.Analysis.Dsp.Transforms.RealFft(recordedData);
double[] magoutput = new double[fftOutput.Length];
for (int i = 0; i < fftOutput.Length; i++)
magoutput[i] = fftOutput[i].Magnitude;
waveformGraph2.Plots[0].PlotY(magoutput, 100, 1);
(5,179 Views)
Hi again,
as I mentioned before, I was able to conduct the FFT with   Analysis.Dsp.Transforms.RealFft”. But actually I would like to have the result onesided.
So I tried to use “SpectralMeasurements.Measurements.AmplitudePhaseSpectrum”. But I have trouble with the parameters.
I found a descriprtion for the parameters, but that doesn’t help much. Do you have any example how to use the method?
Thanks Heiko
(5,164 Views)
Heiko,
There is example code that is documented in the Measurement Studio Help for the Measurements.ApmlitudePhaseSpectrum Method. A trick for pulling up the help for a particular method is to place your cursor in the method name and hit F1.
-Adri
Adri Kruger
(5,156 Views)
