How do I configure the USB-6501 DIO ports as push-pull?
I am using this code in my Visual C# application to write digital outputs on the USB-6501 after adding NationalInstruments.Common and NationalInstruments.DAQmx as References:
using NationalInstruments.DAQmx;
private static void writeport(int value)
    try
        using (Task digitalWriteTask = new Task())
            digitalWriteTask.DOChannels.CreateChannel("Dev1/port2", "MyPort", ChannelLineGrouping.OneChannelForAllLines);
            DigitalSingleChannelWriter writer = new DigitalSingleChannelWriter(digitalWriteTask.Stream);
            writer.WriteSingleSamplePort(true, value);
    catch (Exception ex)
I want to configure the USB-6501 DIO ports as push-pull. What is the syntax for doing this and will the USB-6501 retain that configuration after power cycling it?
I found this documentation on the NI website:
https://www.ni.com/docs/en-US/bundle/ni-daqmx-c-api-ref/page/mxcprop/attr1137.html
I see that DAQmxSetDOOutputDriveType() can be used to set the drive type to DAQmx_Val_ActiveDrive but I don't know how to access this API from C#. Any suggestions?
(2,667 Views)
Somehow your post is exactly the same except for the difference in language - https://forums.ni.com/t5/Digital-I-O/USB-6501-Drive-Type-configuration-with-Python-nidaqmx-and-NI-MA...
There is  a property to set that in DAQmx in .NET
This documentation is available under C:\Users\Public\Documents\National Instruments\NI-DAQ\Documentation if you have installed DAQmx support for .NET
I don't think the value of this property will persist on power cycle, as a safe bet, always set this property on creating the task.
Santhosh
Soliton Technologies
(2,638 Views)
Accepted by topic author scottmorgan
Thank you for the response. Here is the solution in practice and it works!
DOChannel ch = digitalWriteTask.DOChannels.CreateChannel("Dev1/port1", "MyPort", ChannelLineGrouping.OneChannelForAllLines);
ch.OutputDriveType = DOOutputDriveType.ActiveDrive;
We also have removed all of the weak pull-up resistors from the USB-6501 so that the outputs don't automatically powerup high when the board powers up.
(2,622 Views)
