How do I know how many characters to read using VISA?
I'm trying to write a driver using Measurement Studio for Visual Studio 2005 and I keep getting timeout errors because I'm asking to read more characters than are in the buffer. The number of characters varies depending on the response. How do I know how many characters to tell it to read?
(3,261 Views)
Hi deebp,
If you are using the Serial Protocol you can use the VISA Bytes at Serial Port command to read the amount of data at the port.
If you are using another protocol you will need to implement your own strategy.  One method is to always have your first byte of data sent by your device to be a number which represents the number of bytes of data that are coming.
John E.
Applications Engineering
(3,244 Views)
