How do I move over time to achieve waveform by waveformgraph in vs2003.net
like pic
(4,431 Views)
Hi slave2,
You didn't mention what version of Measurement Studio you were using or what .NET language so I will be using Visual Studio 2005, Measurement Studio 8.1.2 and C# to address your questions.  Okay, so lets get started....
In order to get the behavior you are wanting, you need to consider 3 things:
  1. The property configuration for the UI such that the axis labels display date/time information.
  2. The property configuration for the UI such that the graph scrolls.
  3. The conversion factor between date/time and numeric values.  However, since you are using the WaveformGraph, you can just use one of the PlotYAppend overloads that accepts a TimeSpan increment.
You can configure the UI settings either at run-time or design-time. To get the scrolling behavior, you want to set the the XAxis.Mode property to AxisMode.StripChart. Then of course you would want to calling the WaveformGraph.PlotYAppend.
To set up the date/time information, you could do something like the following:
// Configure the X axis to display date/time labels.
xAxis1.MajorDivisions.LabelFormat = new FormatString(FormatStringMode.DateTime, "h:mm");
Take a look at the Charting and PlotDateTime shipping examples for help.
Best Regards,
Jonathan N.
(4,423 Views)
thanks for Jonathan N.
National Instruments R&D
i am using 7.1studio for vs2003.net ,
as same as this method to solution my question?
(4,405 Views)
(4,403 Views)
Hi slave2,
I'm fairly confident those properties existed back in the 7.1 timeframe but I'm currently not near a computer with 7.1 on it to validate my thoughts. Those properties I mentioned are fairly common so I would suggest go ahead and try it out.  If you have problems, let me know.
Best Regards,
Jonathan N.
(4,401 Views)
Thanks for Jonathan N.
I try it.
another question is how i can show xAxis's Number   like the picture.
eg.
I set xAxis's range (3600, 7219) ,the first number show on the xAxis is 1:06:40 but not 1:00:00.
what should i do. it can show 1:00:00 first.
(4,393 Views)
