How do I save timestamps for each sample?
Hi
I use the module of NI-9234 to measure the signal of accelerometer. I am using the code that "ContAccelSamp_IntClk_AnlgStart" for daq sample code. Now,i want to data add the timestamps for each sample. How do i use the function or example to solve problem?
Nan
(3,597 Views)
Hi Nan,
You may record the timestamp before plotting your data.
Say you are modifying the C# example codes, you can simply add another line of code to record the timestamp right after/before the:
        data = analogInReader.EndReadWaveform(ar);
 same function in VB code can be found at:
        dataToDataTable(data, dataTable)
(3,582 Views)
Hi wellyhuang
Thank your reply!!
I have another a question.How do i change arbitrarily the sample/channel ?
I used the example code:ContAcqAccelSamp_IntClk_AnalogStart.2010
Jan
(3,536 Views)
Hi Jan,
You may try to find the function which is in "DAQmx Configure Code" part in the main function: DAQmxCreateAIAccelChan
Maybe by adding a prompt for inputting the channel name, then pass the parameter to the function (e.g., scanf or getchar, etc.)
DAQmxErrChk (DAQmxCreateAIAccelChan(taskHandle,"Dev1/ai0","",DAQmx_Val_PseudoDiff,-100.0,100.0,DAQmx_Val_AccelUnit_g,50,DAQmx_Val_mVoltsPerG,DAQmx_Val_Internal,0.004,NULL));
Welly
(3,497 Views)
Hi Jan,
Does that meet your requirement?
BTW, since it's a follow-up question, maybe you could create another discussing thread to address this question; thus, if that works for you, you may close this discussion; and if it's not, you may go ahead and create another discussion for this.
Welly
(3,470 Views)
