How to Simultaneous refresh multi plot( wpf graph)
How to use several plot append data simultaneously?
For example, there are 18 plots for Graph. The datasouce of Graph is ChartCollection<Point>[18] graphds
It must execute 18 times of APPEND to update the whole Graph.
Code:
Aps[0-17]=graphds[0-17].append
Dispatcher.BeginInvoke(aps, simulatedData),//executing 18 times
I hope there is a similar data to
graphds.append(Point[18] datasources)
that can refresh 18 plot data at one time.
full code in testmultiplot.zip
thank you
(4,113 Views)
There is nothing special about the delegate created from graphds[i].Append in your code. The WPF dispatcher can accept any delegate. For example, here is a helper delegate for appending to multiple charts:
    Action<ChartCollection<Point>[], IList<Point>[]> AppendAll = ( charts, points ) => {
        for( int i = 0; i < charts.Length; ++i ) {
            charts[i].Append( points[i] );
In your DataWorkerThread method, you can replace the existing aps collection with a var points = new IList<Point>[graphds.Length]; collection, and call the delegate like so:
    while( true ) {
        for( int f = 0; f < graphds.Length; f++ ) {
            IList<Point> simulatedData = new List<Point>( );
            for( int i = 0; i < cyclecountper; i++, x++ ) {
            // Save the simulated data for the current chart.
            points[f] = simulatedData;
        // Dispatch all the work with a single call at the end.
        this.Dispatcher.BeginInvoke( AppendAll, graphds, points );
~ Paul H
(4,097 Views)
Thank you but
I hope DATASOURCE is ChartCollection<CustomClass> ps, not ChartCollection<Point> [] ps .datasource not array
(4,073 Views)
Accepted by topic author jiewei_li
The specific item types involved are not importent. The idea of the AppendAll helper function is just to have a single method to perform all of the append work, rather than invoking for each separate append. You could also define the helper generically and use any data type for the items:
    private static void AppendAll<T>( ChartCollection<T>[] charts, IList<T>[] values ) {
            charts[i].Append( values[i] );
~ Paul H
(4,031 Views)
