How to change Slider step size?
In the older version of Measurement Studio, in the properties dialog for a slider control, one could specify continuous or discrete and specify an interval and base. How is this accomplished in Measurement Studio 2013 in VB>net 2010?
bartj
(5,749 Views)
bartinoregon,
Those options should show up under Behavior in the properties window. They are called CoercionMode, CoercionInterval, and CoercionBase.
If you don’t find them, try sorting the properties alphabetically (there’s a button with AZ at the top of the properties window) and look for Coercion. For some reason they weren’t showing up for me at first with the properties categorized, so I could see where you might have trouble finding them.
Kelsey Johnson
Applications Engineering
(5,728 Views)
Thanks....!
(5,717 Views)
