How to change waveform plot background color from black to white
Does anyone know how to change the background color of waveformplots from black to white?  It's eating up a lot of print cartridges printing out all that black.
(5,345 Views)
You can do this via the PlotAreaColor property on the graph:
graph.PlotAreaColor = Color.White;
Also, if you have Measurement Studio 7.1 or later, you can right-click on the graph in the designer, click "Auto Format" in the context menu, and select a black and white format that will configure multiple settings that are ideal for black and white printing.
- Elton
(5,339 Views)
Thanks Elton -
Stupid me.  I was looking at plot members instead of graph members.
Geoff
(5,333 Views)
I am trying to do the same sort of thing with a VB.NET project and MS 7, but i get an error every time I write something like the line posted above.  For instance:
graph.plots.items(1).linecolor = color. lime
I get an error saying system.drawing cannot be converted to System.UInt32.
I'm pretty sure I'm just missing something obvious, but I still can't see it.
Any ideas out there?
(5,329 Views)
Looks like you are using the ActiveX CwGraph and not the .NET graph
In that case, you would need
graph.Plots.Item(1).LineColor = Convert.ToUInt32(ColorTranslator.ToOle(Color.Aqua))
Bilal Durrani
NI
(5,322 Views)
It's amazing that you answered this just as I found that same line of code by googling system.drawing cannot be converted to system.Uint32 !!!
I had suspected I was mixing up the Active X and .NET components, but I wasn't sure how to get around this.
Thanks for you fast reply!
(5,317 Views)
