How to copy an image to a file?
I am coding under .NET Framework 3.5 2008, in C#.
I have a collection of plots displayed using the ScatterGraph class. I have to include these plots into a a word document; it is a large collection (several hundreds).
Therefore I am considering saving the plots as images and then include the images into the report.
First basic question: how to save a plot to a file
Second: is there a way to copy all the plots together into a word document?
Thanks a lot in advance for your precious help,
GL
(4,838 Views)
I have found this great suggestion
http://forums.ni.com/t5/Measurement-Studio-for-NET/saving-graph-as-image/m-p/1115427 meanwhile.
Where can I find the documentation about the ScatterGraph class?
Basically my main question now is:  how to incorporate a large amount of plots ( ScatterGraph plots with labels axes etc) into a word document automatically? (in .NET 3.5 (C#) ).
Thanks again.
(4,836 Views)
Accepted by topic author actarus
Hi actarus,
Here's what I did to create a word document with text and the scattergraph images.
1. Right-click your project in the Solution Explorer and choose Add Reference...
2. On the COM tab, select Microsoft Word 12.0 Object Library
3. Click OK
The Form I created had a scatterGraph and a button. Here's the code that was added to the top C# source file:
           using Word = Microsoft.Office.Interop.Word;
           using System.Reflection;
This code was added to the Button's callback:
  private void button1_Click(object sender, EventArgs e)
            //save the picture
            scatterGraph1.ToFile("GraphImage.png", ImageType.Png);
             * http://support.microsoft.com/kb/316384
            //create the document
            object oMissing = System.Reflection.Missing.Value;
            object oEndOfDoc = "\\endofdoc"; /* \endofdoc is a predefined bookmark */
            //Start Word and create a new document.
            Word._Application oWord;
            Word._Document oDoc;
            oWord = new Word.Application();
            oWord.Visible = true;
            oDoc = oWord.Documents.Add(ref oMissing, ref oMissing,
                ref oMissing, ref oMissing);
            //Insert a paragraph at the beginning of the document.
            Word.Paragraph oPara1;
            oPara1 = oDoc.Content.Paragraphs.Add(ref oMissing);
            oPara1.Range.Text = "Heading 1";
            oPara1.Range.Font.Bold = 1;
            oPara1.Format.SpaceAfter = 24;    //24 pt spacing after paragraph.
            oPara1.Range.InsertParagraphAfter();
            //Insert a Picture
            string fileName = "C:\\_support\\_reports\\project\\project\\bin\\Debug\\GraphImage.png";
            Object oMissed = oPara1.Range;
            Object oLinkToFile = false;  //default
            Object oSaveWithDocument = true;//default
            oDoc.InlineShapes.AddPicture(fileName, ref  oLinkToFile, ref  oSaveWithDocument, ref  oMissed);
            oDoc.InlineShapes.AddPicture(fileName, ref  oLinkToFile, ref  oSaveWithDocument, ref  oMissed); //image added again for fun
See the above linked Microsoft KB for more information on formatting.
Tanya Visser
LabVIEW Group Manager
(4,804 Views)
Hi Tanya,
Thank you so much for your prompt reply and efficient solution.
I was heading toward the same methodology, but since my experience in VSTO is nil,
I was getting some troubles in missing references and few other things. Everything worked nicely and the logic behind is crystal clear.
I have tried it with a test .png, but I will use my precious ScatterGraphs shortly. I had noticed the ToFile method; definitely very useful.
Thank you so much, once again.
Have a nice day,
Actarus
(4,800 Views)
